Blue Jinn
Rider of the ARPocalypse
I have (some -- only so many cables...) of the acc send/rcv jacks from my M-520 going to a normalled patchbay. (I have e.g. a parametric EQ on that side of the setup, so it seemed convenient)
Which got me to thinking, if I have e.g. an external mic preamp/compressor, line level whatever, what would prevent me from using the accessory receive as a sort of direct in? As far as I can tell from the block diagram the acc s/r is post fader, pre-eq, pre buss assign. So all I lose is the fader meaning I'd need a way to set level at the device with some reasonable accuracy. As long as I keep it at a nominal -10dBv level, I don't see any problem. Thoughts?
