Using a Mixer with Alesis IO26
  • Thread starter Thread starter Ninja_Drummer
Ninja_Drummer
Ninja_Drummer
hey guys,
I currently have the Alesis IO26 and run it through Cubase LE4 that came with it on a Vista 32bit/Lenovo.
As much as I love the multi channels and the clean, crisp sound it puts through, and as much as I hate the constant dropouts and freezes in Cubase (probably cubase's fault). I was wondering if I could use my Behringer EuroRack UB2222FX-Pro 16 input mixer along with the interface and run it through 1-2 inputs on the interface. i know it's possible with higher end Interfaces and what is primarily done in studios, but was wondering how well it fares with the IO26.
My mixer has 2 separate sets of outputs on the back. One has 2 outputs that are labeled as "Main Mix Out" While the other set is 2 outputs labeled "Control Room Out". Should I decide to use the mixer with my interface, which set of outputs should I use?
I'm sorta new to the recording process in terms of hardware, so help would be much appreciated.
Ninja_Drummer
The main mix out is for your PA Speakers. The Control room out is for your studio monitors. Either one will work...
But will either one put out a better sound quality than the other? Just curious.
What's with the droning out of dots after every phrase 0.o
I do have a bad habit of doing that don't I? I have to try and cut down on that. Good luck with your connections!
