O
OldGrover
Ok, here's what I have :
* n-track recording software
* 2 x Yorkville YSM-1 studio nearfield monitors
* Yorkville CR-5 "utility" amp - nice match to the YSM-1s in my opinion
* Yamaha PSR-740 - L/R output, used for piano sounds, plus some auto-accomp (more for jamming then recording, but some recording as well). It has some vocoder stuff on it, but I am NOT a big fan.
* 2 x SM58 - used for trumpet/trombone/tuba/voice
* Yorkville Apex 420 - used for ambient/trumpet/voice
* Accoustic guitar
* cheapass Yamaha drum machine which I misremember the name of - not used much at the moment, but want to be able to plug it in
* SB PCI128 for Midi, plus aux audio
* Delta 66 soundcard for main audio (4 in/out - no digital in use yet)
* Mackie original 1604 mixer
* hifi tape deck (I get a number of requests to take demos from stereo tape and put 'em on cd)
* (there will be a few more mics and sound sources added from time to time, as well)
After perusing the Mackie manual, here's what I think I want to do. The idea is to give me the ability to mix any 4 sound sources at once without replugging. Opinions would be helpful....
*Connect Apex (main mic) to channel 5 of the Mixer. *Connect SM58 (2nd mic) to channel 6 of mixer.
*Leave 7/8 open for now
*Connect all other sound sources to other channels. On all those sources, hit the mute/alt button so output on all those channels going out the Alt stereo bus, rather then the main bus
*Connect Alt Stereo outputs to channels 7/8
*connect input of Delta 66 breakout box to the channel 5-8 channels aux output (which will disconnect channels 5-8 from the main bus as well)
* at this point, nothing is going to main bus. channels 5 and 6 go directly to the Delta 66, everything else gets redirected to 7/8 before hitting the delta 66
* using the mixer aux stereo input 1, bring back the 1/2 output from the delta 66 to the mixer main bus.
* connect main output to the amp, amp to monitors
* connect headphones to headphone jack on mixer
* connect tape deck input to delta 66 output 3/4 (I get requests for stuff on tape, as well. sigh - old technology)
* at this point, I can switch between monitoring the stuff going into the delta 66 to monitoring the actual output result of my N-track work on the PC. I can use headphones when recording stuff in (no control room - sigh) just by hitting main output mute. And I can add and remove components just by moving faders and/or removing recording streams in n-track
Am I on crack? Is this reasonable? It seems to me that this should work.... is there a sound quality problem anywhere? Obviously, there is going to be SOME degradation since I bounce some channels through the mixer twice, but is it going to be noticeable?
* Accoustic guitar
