US/UK equipment query
  • Thread starter Thread starter Alex H
A
Alex H
Sorry...a really dumb question coming up...
If I were to buy a product from a US store (probably Computer Audio in this case), would it work in the UK? The plug would presumably be a problem, but would the thing work with an adapter? What I want to pick up is a Fostex hard disc recorder, FWIW!
Thanks in advance!
Depends on the transformer. Some bits of kit will happily run on either 240V or 110V others will not.
If it is a "not" then you will need both a step up (or down) transformer and a plug adapter.
The differance in frequancy should not be a problem.
Hope this helps
Hope this helps
Thanks a lot. I've sent the seller a query about it!
Just noticed this
GENERAL
Dimensions 312(W) x 264(D) x 88(H) mm
Weight Approx. Approx. 3 kgs
Power Requirement 100V - 230V, 50/60Hz
Power Consumption 14W
On their website. Do I understand right that I'll only need an adaptor, and not a transformer?
