Dionna Blue
Accentuate the positive.
Ok so I got my stuff today http://www.music123.com/Pro-Audio/R...ro3-Recording-Package.site7prod486268.product and here's how it's goin so far...
Setting everything up was easy enough I didn't really have to read anything except that I had plugged the speakers into my laptop instead of into Alesis with the patch cable but I fixed that right off. And then the fun began...
No sound in Cubase. Ok well I'll go to audacity just to make sure everything is connected right. Mic works in Audacity, but no sound from headphones. A couple hours later I finally got Cubase up and running - had to map my inputs and select the devices in the AISO driver menu and some other stuff that in my mind should be automatic.
So now we're ready to work right?? Wellll not exactly. My mic barely makes a sound unless the gain is at max on Alesis and then I hear that white noise. I can't hear it on the track, but I can hear it in silence so I know it's there. Hopefully the pre-amp and a better mic cable will improve that. Also, I don't know if there are settings in Cubase that would help?
As for the mics - I'm not impressed with the MXL V63M or the Shure 48-LC. I'm not sure what all the hype is about...to me they perform only as well as you would hope any fairly decent mic would. Again, I may see some improvement when the ART Tube and other mic cable arrive.
The Nady shockmount barely fit the MXL, I had to really cram it in there but it's lined with soft fabric so it doesn't scratch the mic. Two of the rubber bands look like they've been repaired and have what almost looks like electrical tape wrapped around them! What the...!!! I will never by another Nady product. It was only 15 bucks but come on...a repaired rubber band! The headphones and monitors are also probably just enough to get me off the ground. I'm pretty sure I will take advantage of the 45 day return policy and trade this stuff in for better gear. For $275 bucks I feel like I got my money's worth...and as we all know...275 doesn't get you much these days.
Don't waste money on snakeoil mic cables unless the one you have is faulty it should not add or take anything away from your sound.
Fair enough.
