pipelineaudio
This is another something I put on a local BBS but I think might be helpful here. You can show it to bands coming to you, so I can look like a dick, but still you get to tell themwhat they need to do without looking like a dickphor
Funny thing. Many times when a band is looking to book my studio, the first thing they ask is " whats the price ? " The fact that that should be near the LAST question they ask is for another discussion
My point is: IF you are worried about cost, then why the !@#$ mutha!@#$# goddamn ^%&* hell, would you blow most of your time on stuff that could have been totally avoided, saving you half the cost of making your record????
It makes me feel bad...VERY bad
Dont get me wrong, I dont mind taking your money, but I would rather be putting it into your album than intonating your guitars on the studio clock
OK, so even tho I will be loosing money from this, Im gonna put up some URL's that I hope will save you SERIOUS time in the studio, save you some money, get a better sounding product, AND hopefully youll learn that you can do most of this yourself( not to put any techs out of business,but...)
OK first of all intonation of guitars and basses. For those who have dealt with me before, I always warn about this ahead of time right? Well, many times Ill get in guitars and basses that are so far off any tracks they make will be unuseable, until they are repaired
http://www.virtualguitarmagazine.co.../Intonation.htm
thats a pretty good link. The gist of it is,
play your 12th fret harmonic,
tune it right to pitch,
now HOLD down the string on the 12th fret
check the tuning
if the fretted note is sharper than the harmonic, make the string longer, by moving the string's saddle AWAY from the neck
if the fretted note is lower than the harmonic move the saddle towards the neck
this can get tricky on floyd roses, but its something you ought to learn to do.
Repeat until the string is perfectly correct then repeat for the other strings.
ANYTIME you change string sizes, adjust the action ( string height), adjust the bow of the neck ( truss rod), and FOR SURE before you go into a studio, check the intonation. Weather can also play havok with this. You will be amazed just what your guitar can sound like properly set up
OK now, DRUMMERS!!!!
anyone who has worked with me knows what a drum nut I am ( tho Im actually a guitarist )
Drums will usually be the most expensive part of your recording session. For the most part the drummer MUST play the whole song right all the way thru, tho we know there are exceptions. Drums take the longest to mic and get tones for. If your drums arent up to snuff, or your drumming skills arent up to snuff, right then and there at the very beginning of a session, your album is already compromised. There is precious little to do to possibly make up for bad sounding drums or poorly played drums
ok first of all AVOID like the plague, drums that have matching dimensions. That means, if the kick drum is 22" diameter AND 22" deep, there are going to be problems. Not going to get into the accoustic theory, but matching dimensions are usually VERY bad news! VERY VERY bad news. The waveforms generated by such a drum tend to cancel each other out and have no " throw ". Even at the tuning point of maximum resonance these drums dont have much to say. A very popular manufacturer ( DW ) who used to, and many times still does, make excellent drums, is guilty of this time and time again lately. I dont know whats going on over there, but just because it says " DW " on it is no guarantee of anything!
Next, THROW AWAY the factory heads. I dont care if theyre on the bottom where they dont get hit, doesnt matter. These glorified pieces of Saran Wrap need to GO!
Unless you REALLY got confidence in the distant mic sound of your kick drum, make DAMN SURE theres a mic hole in it, and make sure it isnt too low to get a mic in...your live sound guys will also thank you for this
Take a VERY careful look around the drum for cracked screws, hardware, missing lugs, and loose anything...I kid you not, on more than one occaision drums have come in missing lugs, with the drummer unaware....I am NOT joking
http://www.drumweb.com/profsound.shtml
that link is great. You may agree or disagree with many of his findings and techniques, but they DO work, so its a good start...PLEASE if you are a drummer read that link
OK so we got the technical side out of the way, just as importantly ( perhaps more), is the performance side of this, but I'll leave that for next time
Aaron Carey
StudioZ/Pipelineaudio
www.studiozpro.com
pipelineaudio@angelfire.com
(602)954-6185
check the tuning
Aaron Carey
www.studiozpro.com
(602)954-6185
