J
jkokura
les666paul said:so what about the AT 4050
As long as you know it's NOT a tube mic - it's a multipattern - it's a great mic.
Jacob
soundchaser59 said:One other thing to keep in mind, today's "tube" mics are not the same as yesterday's tube mics. Today they put "tube circuits" in the mic, not an actual vacuum tube. I almost bought a tube mic but I called the manufacturer first to ask them which tubes I could switch out to colur the sound differently. They laughed at me for thinking it was actually a tube in a socket that could be removed and replaced with something smoother or hotter. Instead, they told me it is a "tube circuit" that behaves like a tube but if it wears out you have to send the mic to a service center to get the "tube circuit" replaced.
If you want a "real" tube mic, you'll have to spend the bucks for a vintage item. This also explains some of the renewed interest in tube preamps.
Richard Monroe said:NTK works for me, and I think it is an excellent contrast to MK319, which I also own and use. NTK can be very flattering to a cheap acoustic. All around useful mic.-Richie
Robert D said:Maybe what they meant to tell you is that the tube isn't socketed, and you can't just pull it out and stick a new one in.
-RD
...I have also replaced the tubes in my GT Brick Mic Pre and my SP VTB1 Mic Pre...
mrbowes said:kidvybes,
What tube did you use in the VTB-1. I just ordered a VTB-1 and am interested in anything potential modifications I can make that will lower the noise and/or improve the quality of sound.
Also, how hard was it to install the ciruit in the MXL V77?
mrbowes said:This is why sometimes I hate internet message boards: people can spew off crap like this as if it's the truth.
Do your homework, mang. Generalizations like that are dangerous. You take your one example, which you don't even clarify in terms of vendors and model, and then declare that one needs to buy vintage to get a real tube?
C'mon now, that's pretty weak.
soundchaser59 said:Yup, my bad....... I generalized it because they did. It was the AT3060 I originally called about, the AT tech said all the new tube mics are "tube circuits" no matter who makes it..... not sure why he would say that, other than trying to make his mic sound as good or better than the others. I frequently make the mistake of assuming that the guy on the other end is being honest and knowledgeable!
Your post left bite marks on me, but I dont see any blood.......but I'll keep my distance....hate to fuel any more hatred.....
Dot said:les666paul, what sort of preamp are you using? If you have an MK319 and want to get into a good mic that's not as dark I don't think you even have to spend $400-500 to do that. I'd recommend you look into the ADK Vienna or Hamburg. They run under $300.
My review of them is at http://www.studioreviews.com/vienna-hamburg.htm
And if you already don't have a decent preamp, something like the $150 Rane MS-1b will give your mic much better performance for vocals and acoustic guitar.
My 2¢
