D
dmbfan1981
what should I know about a tube mic? I assume a tube mic will really warm up vocals, but does it connect the same way ( with an XLR with phantom power? ) is it usually a better sounding condenser? Thanks.
What do you mean by the term "warm"?dmbfan1981 said:what should I know about a tube mic? I assume a tube mic will really warm up vocals, but does it connect the same way ( with an XLR with phantom power? ) is it usually a better sounding condenser? Thanks.
Thank you for that. Sanity is good. Toobs are only warm in physical temperature.recordingpro said:What do you mean by the term "warm"?
How do you like your V69M? I haven't used mine yet, but by looking at the chart with the frequency responses on it, I'm a bit leary. That little peak around 10k scares me a little. I had a Behringer B-2 pro with a chart that (if I remember correctly) read about the same...Han said:I have three tube mics, a Neumann M149, an MXL V77 and an MXL V69M.
Only the V69M gets warm on the outside.
Pretty much because the Behri mic sucked. Granted, it was my first mic - on a VERY low budget - it seemed to be WAY too harsh and brittle sounding on everything that I tried. Even in a dead room, with a vocalist who sounded like (gag) that guy from creed. Deep voice still sounded like ass. I am going to fire it up tonight and see what she does, who knows, hopefully it'll be better.craigmorris74 said:Just curious, why would a 10K peak scare you?
pikingrin said:How do you like your V69M? I haven't used mine yet, but by looking at the chart with the frequency responses on it, I'm a bit leary. That little peak around 10k scares me a little. I had a Behringer B-2 pro with a chart that (if I remember correctly) read about the same...
Big Kenny said:Warmth means nothing....
2nd order harmonic distortion can be "pleasing" to the ear, but 3rd order harmonic distortion is harsh and brittle.Minion said:Tube warmth (the sound not the Temp) that poeple talk about is generally 2nd and 3rd order harmonic distortion that sounds very pleaseing to the ear unlike the distortion created in solid state circuits...All audio circuits distorts the signal to a degree (usually a very ,very small degree) it is just that the distortion from Tube circuits actually sound good .....
This is what I understand as the "Tube Warmth" that audiophiles talk about....
