Trying to fix a mistake
  • Thread starter Thread starter microchip
M
microchip
I must have accidentally set my settings in my software to record at 48 HZ instead of at 44.1, so naturally the track will not playback properly when recorded to disc.
The only method I can think of to get a 44.1 recording of the track is to take the mixdown done at 48 and play it through Media Player and record in my software at the same time using the 'what you hear' option selected on my soundcard as the recording source.
However, when I try this, Cakewalk will record what I am playing, but when I play back the new track it end up being totally distorted and often has a ripple-like crackling effect throughtout. I have messed with the settings, but I can't imagine why I can not get a clear recording of that which is being played through the computer.
And I am using SB Live!, and I have all the proper bit and sampling rates set for this.
Thanks in advance,
Micro
Is the 48 track in cakewalk right now?
What version of cakewalk?
I think there are some plugins just for this that will dither it to 44
but others would know better.
Later
F.S.
Dithering is a process of adding "good" noise when decreasing bit depth, it has nothing to do with sample rate (sorry to nitpick!).
Cakewalk can't do sample rate conversion?
You need to download something like Goldwave (www.goldwave.com) and convert the mixdown file to 44.1khz. No worries, it's pretty simple and common.
Slackmaster 2000
Slackmaster 2000
No problem, I thought the same term was used for both.
Ya I went looking on cakewalk and could only find where you could change bit depth...
Later
F.S.
