terminoligy
well, we really need to clarify a couple of things here....
#1 TRS/TS/XLR are all terms that refer to a TYPE of jack/plug, not the size. You can have both 1/4", and 1/8" TRS jacks and plugs....
#2 Working down the chain, you should have an XLR cord connected between the microphone and the pre-amp ESPECIALLY if you are supplying phantom power to the mic.
#3 When you leave the pre-amp, you will either be taking a "MIC" level signal, or a "LINE" level signal. Be sure to match the output signal TYPE to the soundcard INPUT type...ie put the mic out to mic in, line out to line in, which ever you use.
#4 When you go into the computer (99% of generic soundcards are this way) you will go either into a MONO MIC input (on a TRS Connector, it supplies a control voltage for condensor mics on the other contact), or you go into a stereo LINE input on a TRS connector.
#5 Most of the time, it is highly recommended to use the LINE level input insted of the MIC level input, because this goes around the CHEAPER mic pre's on the sound card, and you get a cleaner signal.
#6 MOST, and i say again, MOST of the time, it is not a problem to use a TS cable even when the signal is balanced (supplied on a TRS connector) be sure to read your manual and check.
#7 If your mic pre is MONO, which it is most likely is, when you go into the computer, you will only go into one side of the TRS connector (if you use the line input as recommended)
#8 Yes, you can use a TRS (stereo) cable with a 1/4" STEREO to 1/8" STEREO adapter on the other end to match the stereo input on the sound card.
#9 One last anatomy point, JACKS are the females of the species, and PLUGS are the male counterpart
Hope this helps you to clear things up a little
