andrushkiwt
hey everyone, please leave some feedback for this mix. I had a difficult time with several things: vocal levels, splashy cymbals, and two or three transients that were messing up my ability to limit it where i usually like to. I might have to reexamine my gain staging because I'm just not able to reach the levels you guys are in the mastering sessions. I'm bouncing out of the mix at about -5db. but guitars are usually around -30something. my MBC during mastering adds some db since i up the gain on each slightly, and then the limiter is usually set to -0.03 threshold with +4-5 on input. I use k-14 meter and my averages are around -14 (but i think i should be closer to -9, from what i read). anyways, this might be sightly quieter than stuff you're used to. Those transients i mentioned don't push the db's much at all, but they still come out of nowhere and mess up the mastering process.
of course, thoughts about anything else are always welcome. i took some advice and upped the treble on the amp sim. thanks for that piece of info last time, i think it gave the guitars better balance.
edit: forgot to mention that i would appreciate any feedback on the reverb. I went with a "flat plate" for the first time, instead of my usual "medium studio". pre-delay and wet/dry are still the same, however.
