Blue Jinn
Rider of the ARPocalypse
This is kind of a followup to my other post on line level stomp boxes. I still want to run some of these off an existing (for another circuit) +/-15v
In the attached, the IC connection is pretty straight forward. As to the transistors, I'm not quite sure how to approach that as to the bias for Q1 and Q2 (or if that would necessarily matter going from 9v to 15v. I have an app called AppCAD, which will calculate all the resistor values for that circuit fragment. I don't exactly know how to use it, but it does seem pretty straightforward, plug in the transistor paramters (Hfe etc) and then plug in the voltage range you want at certiain pointes and then some baffling temperature coefficient from emitter to base. THen you plgu in Vcc, Vce and Ic. The AppCAD shows you where all these values occur. In the schematic these are different for Q1 and Q2. I am assuming this is because you want different gain at both those two places, but I have no idea how to figure this part out. If is a matter of gain, I am not exactly sure what is needed where. I am also assuming that Q2 drives the side chain.
Any guidance is helpful appreciated.
The schematic can be found here:
tonepad -- file information
