W
Wanderinjohn
Dell Inspiron 1420 laptop
Windows Vista Home Premium 32
Processor Intel Core 2 Duo T5750 @ 2ghz 2ghz
Memory Ram 3.00 gig
32 bit operating system
Sigma Tel High Definition Audio sound card
Have tested 4 audio programs and they all have the same issue.
Cakewalk Sonar 3
Cool Edit Pro
Mixpad
Audacity
Record on track 1. No stutter. No drop-outs
Record on track 2. Seems to be ok.
On playback, Trk 2 lags Trk1 by a fraction of a second and stutters and then drops out.
I've updated all drivers / turned off applications /
Cakewalk
tried all latency settings / switched drivers from WDM/KS - ASIO - MME 32, and default(?)
Running @ 16bit / 44k - Buffer in playback que - 4
Have run wave profiler and passed.
Tried clock settings - internal and audio (default)
Turned "snap to grid" on and off.
Tested the other 3 programs and they record and playback but the next track has the delay as well.
My studio consists of 2 synths, drum machine, Acoustic/electric guitars, bass, and mics running through a Mackie CFX20, output to Berhinger self-powered 12 inch speakers.
I separated the drum machine from the loop and went direct. In case my cable routing was creating the delayed 2nd track. Same results.
I've reached the end of my knowledge at this point. Any suggestions?
Was considering buying an audio interface, (MAudio Fasttrack) to see if that would correct the problem. Or upgrading My Vista 32 to Windows 7.
But first I'd like to see if I'm only a couple mouse clicks away from fixing this. Someone please help. Thanks
Memory Ram 3.00 gig
Cakewalk Sonar 3
Cool Edit Pro
Mixpad
Audacity
Cakewalk
