rudalicious
Hello guys n gals n whoever else.
I have searched far and wide all over the net but to no avail. Its kind of a strange topic. Well I was doing some mixing for a band the other day... a rock band and since im recording onto a PC i try to get my level as high as possible. After tracking before i do anything i normally try to get my levels so they are just below 0. In the red.
Here is where the question is. I have been noticing it is much harder to mix and get things to blend at this level. Maybe there is just a placeebo effect going on here but i feel if i bring my levels down on separate tracks to say -6 to -3 I can make things fit together better. Now is that all in my head or is it acutally becuase im using less headroom? After i bring them down a bit or dont bring them up then once mixed i bring the mix level up to line with no problems.
Is this the way to go about it? Do you guys have methods you use? Do you all just crank each track as high as it will go? Am i going crazy?
any help would.... help
thanks
thanks
