Hey,, while you have it apart, can you take and post a digi pic of both sides ?
I need to send a pic to "Edcor" (transformers)
I did take some pictures. I hear good things about Edcor, price/performance is stellar.
I do have a bit of mixed feelings that I show these pictures. All of these ribbon mics had excessively loose ribbons except the ACM-4 (dual ribbon). I did go through and tension them all. It's not difficult if you have VERY steady hands, proper tools, a good deal of patience, and awareness of what you are dealing with.
The ACM3 mic body has an i.d. of 23mm. The XLR slug that screws into the bottom is o.d. 22.81mm, and it was able to move all the way through the body.
The amount of free space between the ribbon motor and XLR connector is ~53mm, leaving ~20mm for wiring.
A little YouTube video showing the slop in an ACM-2 ribbon:
(it's a caterpillar!)
https://www.youtube.com/watch?v=nsLDBIOijc8
I followed Michael Joly's tips in this article:
http://www.hometracked.com/2007/08/28/ribbon-mic-sag-and-repair/
I should note that he gives a quick and dirty test to see if you have a loose ribbon, to rotate the mic and listen for "clanging around". With these particular mics there is nothing holding the transformers still in th body, and the transformers will clang in there. So you may be hearing that and not the ribbon itself moving.
Here is the same pic, but I outlined the profile of the motor, and the line in green is to help show any offset there may be. It's where the ribbon lies in the clamp.
These next two pictures are after I tensioned the ribbon. I tuned it to 35hz. Unfortunately I forgot to take a pic of what it looks like held horizontally after tensioning.
Here are some pics of the ACM-2 ribbons I got. I also tensioned these ribbons. I tuned the ribbons to 30hz for each. (these pics are not tensioned)
Here is a good way to tell if you have the ribbon equidistant between the magnets. Hold a flashlight under it.
The ACM-4. It is not easy to take apart, I used a plastic hook and pulled up on the grille on one side. Be careful not to dent the grill. there are no screws or glue holding it together. It's just a very tight fitted piece.
The ACM-4 is the only ribbon of the ACM 2/3/4 that uses a Mu-metal can over the transformer.
Tools of the trade: Note the dust mask! I am not kidding, a little breath will blow the ribbon like it's nothing. Also make sure you're without a dog, forced-air heating, fan / etc in the room.
