A
Alex W
So I learned a couple of lessons the hard way (is there any other?) and thought I'd pass 'em along:
Rule 1 - TIN YOUR TIP
If the tip of your soldering iron is not bright and shiny with solder, it WILL NOT conduct enough heat for you components to get hot enough for the solder to flow. Simply melting some solder with your tip does not constitute tinning. If your tip is dark and grimy looking--it ain't tinned.
Rule 2 - DON'T CHEAT
Follow the rules of soldering--heat each component until the solder will flow onto it; then connect 'em together and heat the joint until they meld. If your tip is properly tinned, the flow should start within mere seconds. If you find yourself sitting there for longer struggling to hold the iron still long enough to heat whatever it is up--you need to clean and/or re-tin your tip. If you cheat and melt the solder with the iron and let it dribble onto the joint, you won't be happy with the results--trust me, I know from experience.
That's it for the rules; a final suggestion would be to get a soldering station with a holder and sponge for cleaning the tip off regularly (like every other joint). Radio Shack has a decent one for $20--well worth it.
Happy soldering!
Alex
Happy soldering!
Alex
Yep still gotta do that.
