This kick sound
  • Thread starter Thread starter Vigo
Isn't the common technique to layer an 808 bass note into the kick? In the first song especially, the kick sounds more tuned and melodic than a standard kick.
I'd also do some research into drum EQ. You can do a surprising amount of shaping of a drum's tone with EQ.
I would try this . Take a separate bus of the kick and significantly compress it after using an eq to boost the lower and high range . This will really pump it up . Ive just learned this technique myself and has really helped my mixes . Parallel compression . The secret is to not be shy on the eq . Boost it real high below 150 to 200 k and anything above 8 k . Slowly blend this in with the mix and find where it helps the most .
Hmm i'll really have to try again. I did try and layer a simple sine wave with each kick but i didnt get the result i wanted... I'll do try toying with some eq more, thanks for the help guys
