Do you know anywhere where you can get channel strips? I'm prepared to build it bit by bit though as I can solder quite well, and as for previous experience I have absolutely none! Do you have any suggestions on books or glossaries?
Thanks a lot
Jered
I am not aware of a DIY channel strip project. There are lots of DIY pres, compressors, and an EQ or two, but all together in a single PCB, I don't know. Also you would still need the aux sends and group assigns.
The other route is to buy channel strips that have been pulled from another console. You can find those for sale without too much trouble.
BUT the problem is you have a case you are trying to fit. Thus, if there is a channel strip out there, somehow you have to bang that into the case you have. If the pot holes don't line up, then you have to wire all the pots point-to-point, and find a way to mount the board. Then you still have to pull together a master section and power supply from somewhere.
The best course to proceed if you are set on your existing case is to find pieces of schematics you like (pre, EQ, compressor) and pull them together. If they come with PCB designs, that might give you a starting point for yours. The PCB design is really going to be killer. Knowing how to solder is a long way from knowing how to layout a PCB, much less designing the circuit that goes on it.
If you take a modular approach, and build a power supply and pre section, and a very simple master section (say a stereo bus with headphone, maybe), you will be able to use published projects pretty much without much modification, and get your fingers wet. You can then add EQ, compression, and more routing as you get experience and money. Ultimately, that is more expensive than doing it all at once (the PCB costs add up quickly), but you are much more likely to succeed, and also have a useful project along the way.
