barefoot
barefootsound.com
This is not an advertisement, and I hope it doesn't seem like I'm trying to sell anything on this BBS. It's just that I have a design for the ultimate set of near field monitors, which I am dying to build, but I don't have the money. So, I'm offering them at cost to anyone who is willing to front the money for the parts. What's the catch?.... Nothing, but a mere $5000!
Why in the world would I pay five grand for a set of monitors, you ask? Well, you wouldn't unless you had tons of spare change, and you wanted the very best that money could buy.
So what is this design?... I thought you would never ask! It's based on an amazing ribbon mid/tweeter unit out of France called the Raven R3. It is an ultra light weight 175mm(7 inch) aluminum ribbon stretched between extremely powerful neodymium magnets. It's response is ruler flat from 500Hz to 30kHz at 99dB/W/m efficiency, and the waterfall plot (transient response) looks like El Capitan! This is an absolutely incredible unit. The problem is the R3's go for $1650 a piece. Way out of my budget, but maybe not for some very fortunate soul out there. I just want the pleasure of building these things.
The main reason I can make the ultimate set of near fields using this R3 unit is because of that beautiful 500Hz-30kHz spec. You can cross this thing over at 500Hz! At 500Hz the wavelength is over 68cm (2 feet), which is twice as large as the physical separation between all of the drivers in my two-way design (R3 plus twin 165mm midbass drivers down to 40Hz). I won't get into the physics, but this means the near field (quasi-anechoic) response is virtually immune to all positional dependences. This is not true for normal designs where the crossover is in the 2-3kHz range. Most of these monitors are designed for flat "near field" response at a very specific listening position relative to the drivers. Small variations in distance, vertical or horizontal angle relative to the monitors can wreck the response. My R3 based monitors will not have this problem.
Another great thing about the R3 is that it acts as a line source above 4kHz. So, it's vertical polar response becomes sharper at higher frequencies. This will dramatically reduce early high frequency reflections off the mixing console or workstation which alter response and smear imaging, without the inherent distortions induced by directional horns. Finally, there is the sound....... These monitors will sound like nothing you have ever heard before.... linearity, detail, and transparency unequaled by anything out there today.
[Couple them with comparable subs (for which I also have big ideas!) and you'll effortlessly fill a large studio with immaculate earth quaking sound.]
Do you have about an extra $5k laying around to help me bring this monitor idea to life? You'll be the envy of us all
barefoot
barefoot
