stevieb
Just another guy, really.
Having a big vent hole in one's kick drum reso head is a fairly common thing. There was some banter about using a coffee can to melt/cut the hole in another thread a while back- some wondered about it, some said they liked it, some said they hated it. Well, I have a kick-drum head that was split, almost to the ring, and figured, what the heck- now's a good time to check this method out.
I removed the head- didn't want to damage the hoop or shell- and brought it and a large. empty coffee can into my kitchen. Put the can, open side down, on the largest burner of the stove, and the head on a cheap rug on the floor. Turned the burner on, and waited 'till the can began to smoke
Using a towel, I inverted the can on the head, and just let it sit there, the only force being it's own weight. The can cooled too much to completely cut/melt the hole, so I had to do it again. The split was very long, so I repeated the process and cut another hole at the other end of the split. This time, I pressed down on the can, and it cut through the first time. Had to do a third on the split section between my two holes, and this time I got the can a little too hot and it scored the rug. Glad I used the cheapie rug!
Contrary to other reports, the cut was fast and easy, with very little black soot on the hole. I am talking almost NO black marks- I had to look carefully to find them. The edge is only slightly rough to the touch, but again not noticeable to the eye. This was my very first time doing this- I was about as noob as one can get at this. Compared to a pre-holed head, the hole is smaller, but not too small. With the triple hole, one would have no difficulty putting a pillow or mic inside one's kick drum.
So, if somebody tells you this method sucks, I'd bet they have never actually tried it. So little "technique" is involved that virtually anybody could pull it off- if someone flubbed this, they got issues!
