B
brra
Hi everybody,
I have a trident s20 and neumann M147 tube. I record the voice thru a motu 896HD and i run logic pro with a dual g5. But i don`t know much about compression, eq and recording tecniques :
So if someone can be so kind to give a hand, I have a few question..
1)To record the perfect vocal track, should i compress the voice while i`m tracking? Can i do this with a the compressor plug in in logic? How much i have to compress while i`m tracking?
2)How much is the distance between the pop shield and the microphone? How much is the distance between the pop shied and the singer?Is it true that the mic must be at the same height singer s nose?
3) On my s20 i have low cut knob but i don`t know how it`s works...Wich freq. should i cut when i`m tracking?
4)About when i mix, how much i have to compress? And about attack and release? Should i set soft or hard knee?
5)Can U guys reccomend me the best compressor for logic audio?
Peole say waves renaissance is the best..
6)After i recorded the voice should i put some eq? Wich freq. i have to boost for get a clear, warm and present voice?
7) Someone have some other suggestions or tips to get the perfect vocal track?
Thanks to everybody!
