I noticed that my bank-change commands had no effect! Way to mess with MIDI beginners Garritan!
Oh well, I still love how it sounds.
And that would explain why, when I bring up the plug-in, some of the keys on the keyboard are a bluish-green and one purple.
I think it fair to say that GPO4 probably wasn't intended for beginners!
Although, if you use the notation program Finale, it's all done for you as you enter e.g. a 'slur' mark, the notes are overlapped, and the MIDI legato 'pedal' is pressed and released as required. When you mark the score as going from arco to col legno the key switch is inserted for you.
Actually Gary wasn't the first to load instruments this way.
There are many examples, including most of the most prestigious orchestral sample sets, that work in this fashion.
And, most notably, many instruments (most? all?) in Kontakt work in this fashion.
It's become the new 'normal' for sample based orchestral libraries.
Here's the list, as an example, of how the Stradivarius KS (key switch) loads into ARIA.
The samples are listed in order with the key switch note first.
Either the whole sample set is loaded into memory, or the beginning of the sample, then the rest (the tail) is streamed from disk as needed.
The key switch notes are in the octave below the lowest sounding note.
C. Sustain.
C#. Sustain mute. (the sound of the violin with the mute clipped across the bridge)
D. Auto alternate. (alternate up and down bow strokes)
D#. Up bows.
E. Down bows.
F. Pizzicato.
F#. Tremolo with mute.
G. Tremolo.
G#. 1/2 step trill with mute.
A. 1/2 step trill.
A# (or Bb if you'd rather). Whole step trill with mute.
B. Whole step trill.
All the sample libraries I know of only have samples in the actual instruments range, i.e. play the equivalent of the lowest A on a piano keyboard to a violin sample and silence ensues. Unlike virtually all 'normal' MIDI instruments.
Orchestral libraries e.g. from East West have even more key switches.
The Vienna libraries even more still, I understand.
Also with Gary's libraries the note on velocity, on non-percussive instruments, doesn't control note volume/timbre, just the degree of 'attack'.
He uses expression (CC#11) or wind (CC#2) and more strangely (CC#1) modulation wheel to control note volume.
There's also a controller to adjust the decay portion of the note so one can get realistic sounding short note playing on rapid runs, and so on.
Two further controllers are used to apply 'variation' on repeated notes (both in intonation and tuning) to avoid the typical MIDI 'machine gun' effect.
The modulation wheel is used for note volume (e.g. on strings (except pizzicato), woodwinds and brass) so it can be easily played live with most keyboards, without needing an expression pedal.
It's a very imaginative way of taking the basic MIDI specification and using it to emulate live music instruments, much needed for realism in orchestral pieces.
Better stop now, other things to do.
Have fun.
Regards,
John.
