X
		xstatic
Actually, sidechaining an EQ to a comp does not really act like a multiband compressor.  It's actually a really cool trick.  Compressors all have their own individual frequency curves in which they respond to before compressing a signal.  When you have the threshold set, that is a basic setting.  The frequency curve that the comp responds to is based around that threshold, but is not always the same for all frequencies.  At 80 hz the comp might trigger sooner than say at 2 khz.  Maybe think of the Fletcher Munson curve as a loose not necessarily related graphic image.  Sidechaining an EQ allows you to retune that curve as it were.  If you sidechanin a graphic EQ and boost 2khz, the comp will respond to 2khz a little sooner than it would have prior.  Conversely, by cutting alot of low frequencies you can greatly change a compressors reaction to low frequencies so it is more likely to start compressing when higher frequencies hit the set threshold.  When sidechaining an EQ to a compressor the EQ boosts and cuts do not affect the audio path itself, so the signal is not EQ'ed, but just affects the compressors algorithm so to speak (at least pertaining to threshold and frequency).  Kind of like Key filtering gates.  This would allow you to "tune" your compressors reaction to various frequencies at various thresholds which can greatly affect how a compressor sounds and acts.  It's one down and dirty way to really make something like an Alesis 3630 sound much better than it really is.
Some (or I guess even all) of this may or may not be correct, but this was how it was all explained to me years ago. I have used this trick on occasion and it definately changes how a compressor acts. It can be very hard to get used to, but sometimes it really does the trick well
