Tascam Portastudio Mf-P01 - Input Mic/Line issue
  • Thread starter Thread starter fuzz_overdrive
F
fuzz_overdrive
Hi. I have an issue with the input jack of this Tascam portastudio mf p-01, I’m wondering if it’s a soldering problem or the jack connector inside. If i connect a normal guitar jack there's no signal at all also if i move the connector..instead if i change the jack adapter..works but only with high frequency and a low signal instead with a normal jack cable for guitar or bass doesn’t work at all. Thank you in advance for the help.
Hello, I'm also having an input issue with my MF-P01. Mine isn't getting input at all. I've cracked mine open and there doesn't seem to be any broken connections around the input jack.
Have you opened yours?
Sounds like maybe we both have bad input jacks. I've read it's not too difficult to switch them out, but I don't know where to order a replacement part for it.
If anyone on here has ever done it, I'd love some advice on it.
Good luck with your MF-P01, Fuzz.
I'd love to get mine working again, too!
