The Swill Man
hi folks, hoping someone can help with this issue. i've got a Tascam Porta Two here that i'm fixing up. i replaced all four belts in the tape mechanism (all were stretched out) and now i'm encountering a strange problem. when i try to play a tape, the heads rise up and make contact, but the pinch roller doesn't go high enough. and then playback aborts a second later. the machine could probably use a new pinch roller anyway, but i don't get what's going on here. if i manually nudge the pinch roller arm upwards, the roller makes contact, the tape moves, and the meters go, because the heads are already in contact. but for some reason, hitting Play on its own doesn't move the pinch roller upwards quite enough. i can't see anything obviously broken or bent, etc... any hints? i hope my description was detailed enough. thanks.
