N
		neckcarpenter
As the title says...
I'm testing a Porta One and if I record over a pre recorded cassette, tracks 1, 3, 4 fully erase, and only playback my test recording. But track 2 retains maybe 40% of its original recording.
I've also tested it with my own recordings on the Porta One and the same thing happens. My recording also is only *mostly* erased but not all, when I go back and record over it. It seems to retain mostly the low end, sounds like?
I'm assuming this is an erase head or record head alignment issue. Is that where I should be looking? And if this is the issue, how would I correct it without one of those fancy alignment tapes?
What I do love about the Porta One is that you can access the heads without taking the machine apart. (Just discovered that today...)
Here's hoping this isn't totally out of left field, and thanks for looking!
