tascam porta 02
  • Thread starter Thread starter Jake123
J
Jake123
it won't playback through line out or phones. all i get is this buzz and sometimes it kind of boosts up noise and goes straight back to hum. i can only hear a faint noise of the recording. what do i do?
Send it to Tascam for repair.
It could be a blown amp chip or maybe broken head wires. Either way it might be best for bench repair,... or at the outside pop for a new on on clearance, $99, might be cheaper than repair. I'd call Tascam for a quote. I know it's annoying, as you didn't abuse the unit or anything. I've had my own problems with the 02mkII, and I think there's something weak in the chain of components that make up the entire product. Sorry.:eek::eek:;)
I'll tell you what, I have a couple 02mkII's with similar problems, so maybe I'll take them apart and have a look inside, then report back later if it's anything obvious. I still think up front it may be head wires, cold solder joints or op amp chips that don't hold up. Good luck.
Last I checked,...
Tascam has a (appx) $60 estimate fee, that applies to the price of the complete repair if you go that way. It's not a bad deal, and it might not be an expensive fix. After all, it's such a small and stripped down unit, it's probably exceedingly easy for Tascam to fix.
BBL::eek:;)
thank you a bunch! It just makes me sad cuz i bought it used for 80 bucks like 3 weeks ago, and it never worked quite right. ebay sucks sometimes
Tests
I've checked [2] Porta 02mkII's with the same problem.
Both record fine on all 4 tracks, but have no playback on any track.
One Porta 02mkII I'd marked previously as only "Track 1 No Playback", but apparently the other 3 track's playback failed in the interim while being stored in the box.
The track tests verified okay on another cassette deck as sound printing to tape.
There were no obvious things like loose connectors, burnt components or broken wires in the unit.
One 02mkII makes a definite oscillating squeal thru the playback mixer on the headphones at power up, but "zaps" down to nothing in about a second. A real electronic failure sound.
There is probably a single a chip with the playback amps that has failed, and therefore would need service and component repair.
It may be a bit beyond the simple DIY'er, lest you have the service manual and some test tools.
I may buy the Service Manual for further checkout & take another shot at repairing it.
I might schedule this (and other gear) for TASCAM Service at some future time, TBD.:eek:;)
Sometimes submitting to Tascam Service is the most expedient and cost effective thing to rescue some of these units. Authentic Tascam Service in Montebello, CA., is the only repair shop I'd trust. Fortunately, the Porta 02mkII is small and easily shippable. It's drive time and dropoff for me.
My failing Porta 02mkII's are otherwise like new and not abuse, but are hardly used. They were sold as working devices. I believe it to be a weak component.
I don't DIY much any more, but I did a basic teardown to look at the insides and came to these conclusions.
Yeah, mine were eBay deals, too! Don't you love it?:eek::eek:;)
Bench repair on this type of unit is a tough choice, based on a brand new unit being only $99 on clearance. It might be best to call for a quote or to discuss with a TEAC repair tech for "analog".
On the other hand, you may also occasionally get this unit off eBay for $30~$40 and come away with a working unit. Ebay is funny that way. That doesn't take away from my feeling that this particular problem is a common or class problem with the unit.
'Nuff said.
