I've been following the other MS-16 thread and see there is a lot of knowledge on these machines here so I'm hoping I can find some help for my issues.
My MS-16 works great... for the most part. I however have 4 channels with limited range on playback it appears. One has no low frequency response (nothing under 300hz) - If i record on the channel its fine, but repro and sync modes are very thin on playback. If I swap card the recorded material sounds fine.
Then I have 3 more cards that are out of spec on the high end in repro and sync (maybe 5db out... so not pleasant... rolled off).
Any idea where to start replacing caps to try and remedy the situation? I'm good with an iron and I have a Hakko 808 so desoldering is no issue... just need some guidance as to what to replace.
All ideas welcome!
All ideas welcome!
