			altruistica
Member
I've read the manual and other posts here that warn about using both XLR and RCA input jacks at the same time. I can see by the schematic that the XLR inputs come before the RCA inputs, but that they then are fed into the same circuitry, so you wouldn't want to use both at the same time for risk fo overloading the input.....but what about the outputs?
It would be useful if both sets of outputs could be used (or more specifically permanently wired up) at the same time. I want to connect the XLR outs on the MS-16 straight into the back of the TASCAM MX2424 inputs, so I can dub from one to another and also record analogue and digital at the same time. I also want to leave the RCA jacks connected to a patchbay which are normalised through to tape returns 1-16 on the Allen & Heath GS3000.
I'm still not sure what caused the diodes to blow on the machine (and fuses) as I set up the machine at the beginning of the week, but if this was the reason then I don't want to repeat the episode. My own feeling is that I may have setup the machine inaccurately the first time (setting the 250nWbm MRL tape I have to -3VU) which then when I tested the machine recording 1K, 10K, 16K and 100Hz tone at 0VU would have been actually putting +6 onto the tape across all 16 tracks. The machine crapped out after recording about 16mins of tone......It might not have been the problem but that I had the XLR outs going into the MX2424 while the RCA were connected to the patchbay (though nothing was connected to them at the time....nor normalised, just sole patchbay points.).
Anybody know?
Thanks,
Al
Anybody know?
Thanks,
Al
