sweetbeats
Reel deep thoughts...
Does the M-One XL just have two inputs and two outputs? If so, then yes you could just bring the output of channel 1 on the effects box back to channel 17 on the M-520, and channel 2 of the effects box back to channel 18 of the M-520. Or if you already have the LINE inputs of channels 17 & 18 on a patchbay, then you could bring those two outputs from the effects box to the patchbay, sure. But consider RFR’s advice about getting a simple setup going first, with direct connections to the console backplane and get stuff going, and then you can branch out from there. It does three things: 1. Gets you up and running, 2. Helps you focus on the console’s operation without too many external variables/distractions, and 3. May redirect what you *think* you need now and reveal to you more patently what you really want to do with your setup.
You could alternatively, if you’re not using both 2TR A *and* 2TR B inputs, use 2TR B L&R on channels 19 & 20…they are the same type of inputs as the LINE inputs, but you have some enhanced monitoring capabilities there…direct monitoring in the MONITOR SELECT switchrack, as well as inline monitoring via the AUX 3/4 busses. You may not need this, but if you’re not using them they’re there…you just have to make DAMN sure, whatever channels you bring the effects box back in on, you do NOT turn up the send knobs of whatever AUX busses you are using to feed the effects box. That will result in a feedback loop. Like if you’re using AUX 1/2 to feed the inputs of the effects box, and you turn those knobs up on the console channels that input the outputs of the effects box, you’ll be directly feeding the outputs of the effects box right back to its inputs.
