Eclipse4449
Member
No, I had a “value” mic set in which I disconnected and bought (2) 7 piece Sure mic kits still in their cases
You definitely understand what I’m trying to do so then in all seriousness should I buy a new console better suited for my needs and sell this one. I’m completely ok with the PGM solution. I have a lot to learn and at 60 years old I don’t know if I have 5 or 10 years to master all of this stuff lolSo if you do it that way what you’ll have recorded is a stereo mix of all the mics. There will be no way to individually adjust levels or tweak EQ or panning or apply any dynamics processing. Like if it was me and I was stuck with the M-224 and had no other option, and I wanted to record a drum kit all mic’ed up, I’d probably at least send the kick to PGM 1, snare to PGM 2, and then use PGM 3 & 4 for a stereo mix of the Tom’s and cymbals, or even use the insert jacks of the cymbal channels to feed the overheads to the interface and have a stereo sum of the tom mics on PGM 3 & 4…but now I’m looking at your pic of the kit…do you have internal mics on the toms and snare?
That doesn’t answer my question.No, I had a “value” mic set in which I disconnected and bought (2) 7 piece Sure mic kits still in their cases
Isn’t the headphone jack on the front panel below the wrist rest?You definitely understand what I’m trying to do so then in all seriousness should I buy a new console better suited for my needs and sell this one. I’m completely ok with the PGM solution. I have a lot to learn and at 60 years old I don’t know if I have 5 or 10 years to master all of this stuff lol
BTW, looking at all of the ins and outs on the back I don’t see a 1/4 headphone jack? I have both wired and Bluetooth the later has noise canceling
Mic listThat doesn’t answer my question.
What mics are on the kit, and what are they mic’ing…make a list.
I’m sorry this is a pain. I started buy all of this gear 10+ years ago. I have the Scarlett 18i20 but do not have the cables yet from the console to the interface but do have enough xlr for each mic.You have…18 mics on your kit? No snare mic or mics? Why so many mics? And you have tons individually mic’ed AND you have a pair of mics to capture all the toms? Each to their own, but I’d never want to mic a kit up that way. You’re going to spend a lot of time trying to sort out the phase issues unless you have a tool in your DAW to help analyze that for you.
And back to the original question, yes if you want to have each of those mics on an individual track in your DAW you’re either going to have to make up a custom snake to use the insert sends as a pre-fade, pre-EQ direct outs on the M-224, or get a different console. And what audio interface are you using? It has to have at least as many channels as mic sources you want to simultaneously record. The 18i20 can do that, but do you have the hardware to convert 8 line level sources to ADAT Lightpipe and 2 line level sources to digital S/PDIF so you can actually use all 18 input channels on the 18i20?
Yes, but after reading this message it would easier to use less mics, as a 10’ and 12’ Toms and 14’ and 16” can easily share a mic so can Cymbals be paired up. At then again Yes on their own track
Ok I don’t know which is better for what I’m trying to do.
What I’ll be trying to do is essentially changing the sound of each piece, or better said take away harshness, add reverb, and use the EQ and place pieces across the sound stage without buying electric drums.
The new mic kits don’t have to use the clips like original kit I have, I can set a stand and mic the 2 toms and the floor toms exactly the way you mentioned above.
I could probably return one or both of those kits and use the CAD pencil mics for everything and reduce the count dramatically, and use those podcast mic stands hanging from my rafters in a different way.
I had a hacked version of Pro Tool for years but didn’t have an audio interface yet, I work at a place I can print stuff so I printed huge amounts “How to” docs and read them. Well that computer is in the garbage so currently none but would rather stay with Pro Tools because I have at least seen some of the stuff it can do. This is something I can purchase/Subscribe to now, I haven’t done it because I suppose I’m working through this all backwards, connecting the hardware.
One of the very first thing I bought was this wire setup I bought from my local music store, it has 4 XLRs. 2 input, 2 output (L&R) on one end and USB A on the other and a housing in the middle which is probably a DAC and was told it would connect my Analog mixer to a computer (That is how it was described at the time)
Is this something I should invest in right away?
The hardware I currently have I knew is only the start I’m sure, I knew I needed more stuff just don’t know what I need. I know software/plugin will be needed to isolate each piece,
CAD GXL1200BP and GXL1200
Oh Crap they all require Phantom power! Any suggestions or recommendations of what can handle 7 or 8 that need Phantom Power
It just another thing I did before not knowing what to do, Reviews said [the CAD mics] are especially good for percussion instruments. I’m in too big of a hurry I guess.
I also just discovered the difference between my (2) CAD GXL1200 is Unidirectional and the (4) CAD GXL1200BP are Omnidirectional and Unidirectional but isn't an issue here.
I see the Scarlett 18i20 (3rd Gen) comes with Pro Tools First, just register the Scarlett and download the Apps. It also comes with Focusrite Control App which corrupted my output settings ( outputs like my sound Blast AE-7, built-in speakers on my monitors etc. vanished, I had to uninstall and clean up the registry to see them again, I eventually had success.
As for Pro Tools I'm not married to it. If there is something that gives me at least 24 tracks I could cut me teeth on that
