P
pelagos
Hi there
I have recently restored a TASCAM M-600. All is running pretty well but an unusual issue has just popped up.
I noticed that the lights in the VUs (all 16 PGM and the Master VUs) occasionally go dim for about 1/2 a second then come back on. The audio is not affected during this time, i.e. it does not drop out - just the VU lights go off/on very briefly. I dont know if the actual VU meters stop or its just the lights cause it is very random and only occasionally so I really only notice it out the corner of my eye then they are back again. So I think its juts the lights but it may be the actual meters stop working as well. I will try to clarify but I can, but as I said it is only occasionally and at random, so hard to actually check.
I am not sure were to start looking to troubleshoot this issue? I assume on the EXT METER PCB ASSY? I believe from the circuit diagrams that is were the power for the VUs comes in?
I though maybe the meter bridge wiring but the fact they all go off/on at the same time makes me think its something that affects them all from one source (ie the meter PCB)
Any advice would be super...
EDIT - It is only the lights that go out - the VU meters still work and audio is not disrupted - if that helps point to a place to start looking
UPDATE - I seem to have resolved the issue (for now at least). I changed the capacitors in the 8v circuit on the PSU and also notice the fan was not working - the PSU was getting VERY hot. I replaced the fan and it now runs pretty cool and I have not had the VUs dim since. Not sure if it was the caps or the fan or both but it seems to have fixed the issue for now!
Thanks
Thanks
