Solved Tascam M600 meter bridge wiring
  • Thread starter Thread starter pelagos
P
pelagos
Hi there...
I am restoring an old Tascam M600. The previous owners pooch thought the meter bridge wires looked tasty and munched through them!
I wired on some new 8pin connectors but I must have not got it right!
The master L/R are not registering and input channel 1 is showing on group 11&12 if I remember correctly. I’ve only got the first 4 input Channel and group channels connected at the moment...
I thought from looking at the circuit diagrams and the only surviving ribbon cable that had a connector still attached that they were just wired straight through but I must have got it wrong.
There are 4 8pin connectors, I assume each is for a block of four group VUs. There is also a 5 pin cable I assume for the master VUs
If anyone can advise that would be awesome...
Thanks
I did figure this out...
I had the 8pin connectors on the wrong PCB's and the L/R master was not working cause i did not bridge the master inserts...
