evm1024
For ages now I've been going to do some mods to my Tascam M-1B line mixer. By ages I mean it started back here in 2008: https://homerecording.com/bbs/threads/difference-between-line-mixers.261115/
The plan is to install sockets with bypass caps and use LME49860 opamps. I've got a bunch of those sitting around but I could try others. The sockets are in but I'm waiting on the bypass caps.
Recap the power supply and recap/upgrade the caps in the signal path. I'll be using some Rubycons in the audio path.
I am considering changing the feedback resistors to a better quality metal film but we will see. The resistors in the pan network also perhaps.
Another thought is that the opamps are running on +- 13 volts regulated and the headphone amp on +-20 volts unregulated. I could see changing the +-13 to +-15 or 16 or even +- 18 or 20. Keeping the headphone amp unregulated would be fine. At some point if raising the rails high enough we would need to upgrade the power transformer to a higher voltage toroid. The PS pass transistors and the headphone amp driver transistors all have a 120 Vceo so raising the rails would not be a problem.
The overload comparator IC is single supply and can handle up to about 30 volts so we are good there. The input network would need to be checked to verify that it shows the correct overload level and the LED current limit resistor would need to be changed for the increased output level.
I'll be posting photos as I go along. This is a as I get to it project so expect photos every once in a while. A bunch or parts will be coming in tomorrow late in the day and the garage is unheated so...
Why do this? Well I needed a project for the winter and this came out on top. It is the only mixer that I have and might be useful once in a while. The only current recording plans I have would be to make dups of any high quality tapes I might be able to borrow or to copy some flac files to tape.
