rog999
Dear All
In the next two weeks I will have a room where I can set up all my recording equipment on a permanent basis.
What a relief that will be. No more getting all my equipment out and setting it all up from scartch every time I need it.
Now I have a permanent home for the equipment I want to set it up to be as easy to use as possible. You know as few cable pulls as possible.
So I ideally would like to set it up so that all my equipment can be input into my Tascam DP02 by using switches rather than constantly plugging and unplugging cables.
The Tascam DP02 has two mono inputs (both line and XLR)
The equipment which needs inputs is as follows
drum machine - two outputs stereo
line6 two outputs stereo
condenser mic - one XLR Mono output
One guitar with XLR mono output
One amp with one mono output
The question is this ( I am sure quite a basic on for most of you) what is the bets means of doing this. I am thinking this would be the job of a mixer .
Howwever I have a number of quesstions about this.
I need a mixer which can be connected to both inputs of the DP02 with both line and XLR connections and then be able to choose which mixer track goes to which DP02 input. Would this need a switching unit of some sort?
The idea is to be able to switch everything rather than constanlty pluggin and unplugging cables which for me really gets in the way of the creative process.
Looking forward to your replies
Roger
Roger
