Tascam dp-008 SD card
  • Thread starter Thread starter twbrownm
T
twbrownm
Hello,
How do I get the recordings from the recorder on to the SD card?
I've tried export and each time the tracks aren't on there.
Googled profusely and couldn't find a solution
Thanks
If you followed the manual on exporting tracks, selecting the tracks, hit next, and then EXEC (execute), the wav files should be on the FAT partitioned area of the SD card. If you put the SD card in a card reader (in the computer or USB external reader), the wav files should be there. Alternately you should be able to access the card by using the recorder as a card reader via USB. Which method of reading the card are you attempting? Either way can you see the card on the computer as a storage device (another drive) even if it doesn't appear to contain anything?
Just my 2 p'oth.....
I have found the card reading slots on computers fussy up to no effin' use at all. The card to USB readers however always seem to work, even the £1.99 things from Rock Bottom!
Tim....... are you still kicking around buddy???? Any success yet? :listeningmusic:
Replies
1
Views
505
PorterhouseMusic
PorterhouseMusic
Replies
0
Views
236
Sunhouse
TascamJimi
Replies
4
Views
970
TascamJimi
TascamJimi
Z
Replies
4
Views
944
Zeebra three
Z
