688
Hello,
i bought a Tascam 388 and during the first tests it appears that track 8 wont
record.
I checked the Channel and Master Faders - ok , all XLR and 6,3mm Inputs - ok, Tape path is cleaned with Isopropanol.
The 388 has been used with Ampex and Quantegy 456 Tapes in the past, which maybe is cut more narrow then the Maxell that I use.
I tried pushing the Tape physically a little bit up and down while recording, still absolutely no signal on 8 while rmx monitoring.
I removed the Top panel, I see 6 cards there on the left side.
Does somebody has an Idea before i try reseating anything or buy a used Ampex Tape to try out?
Could the problem still be one of the Master Faders, they seem a little worn out but work ok.
Thanks
record.
Thanks
