gentlejohn
Hi Folks! Due to ill health & a lot of my vintage gear breaking down on me I have to say: 'I'm having a REALLY crappy year to date!' I'm hoping the good, kind & knowledgeable folks on here can help cheer me up some! So ... after a LONG lay off I've now got my repaired spring reverb unit [a 'Bi-amp MR/140'] back from the workshop & I'm experimenting with the BEST way to hook it up to my TASCAM 388 using it as a global EFFECTS LOOP. From previous insights I think I've got the practical linking up connection side of things clear but my questions today revolve around SETTINGS both (on the 388 as Send & Returns) and on the Spring Reverb unit itself.
I've been tinkering around with it all and what follows is a working arrangement of sorts (but I'm still not convinced I have this Effects Loop operating at optimum performance levels!) Here goes:
FROM THE TASCAM:
- EFFECTS MASTER dial set to MAX.
- INDIVIDUAL CHANNEL EFF SENDS set to taste (anywhere between 7 o'clock & 5 o'clock)
INTO THE REVERB UNIT [Bi-amp MR/140]:
- DRIVE ('Input'?): 12 o'clock
- DRIVE SET (A green LED light that goes from a flicker to a solid light depending on amount of input determined by the DRIVE dial. When this DRIVE dial is set to about 12 o'clock the LED begins to flicker, the higher you go input level-wise, the more solid the light becomes).
- EQ SECTION consisting of 4 dials: 'LOW'; 'LOW MID'; 'HIGH MID' & 'HIGH'. To date I've just left the Equalisation set at 12 o'clock for all.
- BALANCE dial: Goes from 'DRY' to 'WET'. I currently have this set in the middle at '0'
- OUTPUT LEVEL dial: I was 'experimenting' for some time there with this set at 'MAX' but have gone completely the other way for the time being. 'MAX' output was giving me WAY too much signal noise so now I have it set at just: '1'. Hmm? Somehow this seems a bit odd!
GOING BACK INTO THE TASCAM:
- I have the Reverb coming back into the Tascam on EFFECTS RETURN 1 with GAIN on 'MAX' and PAN set in the middle.
Obviously, being a MONO Reverb Unit (plus wanting to use the other AUX for a separate ext. Delay effect) I'm accepting this above Effects Loop set up is MONO. I'm just not confident in my settings and wanting to run it by a few (far) more knowledgeable folks on here to determine whether I'm in the right kind of ballpark with these settings. Any thoughts, advice, suggestions greatly accepted & appreciated!
PS: One of the main things I can't decide on is the DRY/WET balance! When I have it on full WET then turn the dial back to fully DRY it's CONSIDERABLY louder in volume on a Dry playback. Also, is it 'normal' practice to have the OUTPUT LEVEL on an external Effects Loop Reverb Unit SO low??
FROM THE TASCAM:
