Hi all,
I’m New to this forum but hoping some of you may be able to help. I have just acquired a Tascam 34b, it did have a problem with the capstan, the drive belt was stuck jamming the motor pulley. I have stripped it down and cleaned the remains of the belt off. Unfortunately the motor didn’t run. I was expecting more problems I stripped the motor and found the internal inductor was blown. I have replaced the inductor but the motor still didn’t run.
The reel motors run fine and the tension arm switch work as it should, it’s just the capstan doesn’t operate.
I have un soldered the motor from the PCB and tested the motor with a small 12 volt battery and the motor runs fine.
I am now thinking it is the PCB or the drive transistor, so I unsolder the main D880 transistor but that seems fine when tested. I have checked all of the fuses, all good.
Any thoughts or ideas will greatly appreciate.
