FALKEN
ok, before I open this sucka up I thought maybe someone else has had this problem. What is happening is that the right reel is not pulling like it should. the tape is not staying taut. there is not even enough pull to keep the tension arm up. so if you hit stop, the tape unravels a little bit. to get it to play I have to hold the reel up; then it plays fine. but if I hit stop it is not going to stop. well, the left side stops. the right side just sort of acts dead.....works in play, rw, ff...just does not keep the slack tight in idle. thanks.
