cjacek
Analogue Enthusiast
I'm still in the process of servicing my Tascam 246 and noticed something interesting while looking into the faders / sliders from the top of the unit with a good light (faders have not been disassembled). The LEFT / RIGHT PGM MASTER FADERS seem to be built different than the typical faders inside, meaning that each one (Left and Right, which are separate) actually seems to have a metal railing of some sort in the middle (of each fader - that the slider slides on) and the conductive plate / surface on the opposing sides, rather than just one flat conductive surface as the typical low profile ALPS have, with the sliders attached to the sides. I don't know if I'm explaining this right. But I'm just curious if anyone has disassembled these or knows more about how these specific ones are built inside.
I have attached a few photos, very difficult to make, hopefully you can see what I'm talking about. I tried to compare the L + R faders with the normal channel faders. The two faders closest to each other are the PGM L + R and the other is the normal channel fader. The brown element is easy to see in the normal fader (2nd photo) but not in the PGM faders, there's a "track" right there. The reason I actually asked (and you're gonna hate this
) is because I wanted to clean the elements without disassembly (as one of these is slightly crackly and cuts out, although sliding it a few times seemed to "fix it"). I know it's heresy to be even considering that but I just don't have the mind-set right now to be even considering such a painful process. I'll leave that sort of thing to the restoration experts such as yourself Cory.
