F
		finchy
Hi
Using this for the first time and following the steps on page 36 of the manual "Recording the First Track"
L+R BUSS MASTER fader set.
Input 4 set fader set.
Input PAN fully left
Record function SYNC.
Record function L BUSS TRACK to TRACK 1 (Metre 1 lights up, Record LED blinking)
Input 4 to MIC/LINE
Record FUNCTION BUSS R-Track to SAFE.
Now the problem, when I rotate TRIM 4 the Meter 1 (lit) does not react. But when I push the trim up quite high I do get the overload red dot lighting up on input 4 (so it seems it is getting some signal). I can also hear a low signal through the headphones. But this sounds more like it is "bleeding" through and I shouldn't really be hearing it.
If I rotate the INPUT PAN I do hear a clear signal, but it is Meter #2 (unlit) which is reacting and ticking.
Am I missing something? With the INPUT PAN fully left (as per instructions) it does not seem to work.
I have tried this on all inputs, 1 - 4 and I have the same result. I have also tried several sources of sound.
Any help would be appreciated. Is this a defect or am I just a dumbass. Bit of a newb so I'm strictly following the instructions.
Thanks.
Input 4 to MIC/LINE
Thanks.
