Tascam 24 setup question
  • Thread starter Thread starter torq38
T
torq38
Once I have setup inputs levels effects, eq's etc. etc. what is a easy way to save these to transfer to a new song. Example spend a lot of time setting drum inputs and create a new song and have to do it all again. Thanks in advance.
The DP-24 does not reset your EQ and other settings when you create a new song. All the settings you can see on your "mixer screen" remain unless you reset them by a "preference reset" (press the menu button) or you reset them manually. Your fader levels are the only things that do not carry over..........unless you leave them physically in the same position for each track when you create a new song. Hope that helps.
