altruistica
Member
I'm just uploading a video I've made to document a problem I have with one of the two Tascam 238 machines I recently purchased. One of the machines has had the capstan board replaced (although the repairer didn't select the 'double-speed' option of 9.6cm on the board by unsoldering the 4.8cm position and soldering the 9.6cm), so this machine still needs fine-tuning where the actual record and playback speeds match. The other machine has a tired looking capstan board compared to the new board and the tests I've just done seem to confirm that it may well be on its last legs before the 'runaway' capstan issue that I've read plagues these machines.
The test I've done is this. I took a 440Hz signal from a Roland synth, a simple sine wave. I recorded it on TK7 for the new capstan board machine (let's call it Machine 1) and then swopped the tape over to the tired capstan board machine (let's call Machine 2) and recorded the same on TR1. I could monitor the pitch of the tone through the machine on Korg Tuner. Now I think I'm right in thinking that the monitored signal going in to the tuner (ie. from the phono out of the various track outputs) is just a copy of the input signal and not what is actually on the head, yes? When I replayed TR7 on M1 (machine 1) the tone was a few cents flat at the beginning but by half-way through the tape was bang on in pitch. I used the vari-pitch just to fine tune this difference as seen in the film. The pitch on this machine was constant and didn't waver at all during playback.
Is this because of the new board or is something else involved in controlling the speed?
When I replayed TK1 on M2, I was very surprised. The note A when monitored on the tuner was now a very sharp B flat! So the machine was playing back at a different speed than it recorded. By about half-way through the tape, the pitch was still slightly sharp and about three-quarters of the way through the tape the pitch was about right. What was easily discernible though was the pitch falling from a quarter tone sharp B flat through to an in-pitch A over the length of a double-speed SA60 cassette (15 minutes).
Does this all sound like a failing capstan board which can no longer control the speed?
If so, do you think fitting a new board will solve this problem? The boards are advertised on Ebay here
and also here
Notice the different coloured caps?.....I think the new board the M1 has the yellow caps.
I don't think my soldering skills are anywhere near good enough to replace the caps on the original board as the whole board is only about 4 inches square....though if I do buy a new board, it looks like the only soldering needed to be done is around the centre of the board? Can anyone confirm this?
Here is the video:
Pardon our interruption...
www.ebay.co.uk
and also here
PCB Capstan Motor Replacement for Tascam 238 and Tascam 122MKIII MK3 MKIII, NEW | eBay UK
The PCB is NEW, never used. When you buy the PCB, you need to replace it with the old one.
www.ebay.co.uk
Here is the video:
