R
Revell
Maybe someone can give me some insight on this.
I just installed new belts on a Tascam 234 Syncaset. After getting it back together it seems the eject has a problem closing and opening if the door is closed.
I can turn the belt manually (while unplugged) and get it to where it will open and close, but after powering it up it won't eject.
if the cassette door is open when i power up, it won't close. if the cassette door is closed when i power up it won't open.
Is there an adjustment of some sort?
Also, when i first took the cover off to get at the inside (before tearing down to install the belts), i had turned the wheel a little to look at the existing stretched out belt and noticed then that it didn't eject properly. But, i figured it would go away after installing the new belts.
I'm the original owner and i never had that problem while i was using it before.
Any help is appreciated. i hate to tear that thing back down again!
Thanks.
Thanks.
