R
		RFR
I have a thread up in the analog forum, but I'm hoping here might get some traction.
History:
Worked fine started eating tapes replaced idlers. Problem solved
After a period of non use it stopped playing and play function acted just like fast forward
Current:
It had loose belts
I replaced the belts but now she's wierd.
Pinch roller and heads stay up when ff or rewind.
Counter only counts up, not backwards towards zero
It seems pre belt change the pinch roller in down position was default. Now up position is default.
I can get it to go down by manually turning the cam.
Since the counter only operates one way, reverse stops after a few seconds.
All these maladies are new, since replacing the belts, so obviously they are of my own doing.
Since changing the belts, it does play a tape, just along with all these new problems.
But what did I do to create this??? That's what I'm trying to figure out.
I'd be thankful for any help.
			History:
Current:
It had loose belts
