If you want clean juice for audio gear, you'd probably have to invest in a power line conditioner/regulator unit and make sure it was properly earth grounded.
This is something I might have to do, considering I do not have hydro running to my place. This might just solve the problem with my solar power as well, or maybe I should ground my solar panel, and inverter etc. to see if this might help me because the problem lies in both generator and solar power.
As far as an Electrician, I don't think I need one, as my system is far too small to be spending hundreds of dollars, when I could find the answers online.
Although, you are right, if all else fails I might have to call one in if a conditioner/regulator doesn't work, or the grounding I do won't work either!
If that happens, well it might be the fact that the power isn't as clean as audio equipment needs to be, and then I'll be back at square one again.
Has anybody delt with this sort of power before to run, CD burners, Amplifiers, Electric Guitars, tape recorders, etc.?
What did you do to fix the problem?
I'll let you know what happens.
