I've read that the MR8 has "weak" preamps,...
so in practice that means you have to crank up the gain to get a good signal, to the point of boosting audible hiss,... the self-noise of the preamps. I'm not an MR8 user, but I've heard that issue over & over again. It's a weakness in the design of the Fostex MR8, CF memory recorder.
One thing you can rule out is "tape hiss".
Oh,... a solution? I've heard people recommend a small outboard mixer, to give you extra mixing capability, as well as to develop a stronger signal outboard, so you don't have to drive the MR8's preamps to the point that self-hiss becomes audible.
Y'know,... speaking personally,... I kinda hate when another piece of gear is a "fix" to something that's supposed to be a one-piece-do-all item, but it's indicative of the budget gear makers cutting corners and using lesser quality designs and components in order to meet a price point. That's probably another post!!
So,... the Fostex MR8 is an 8-track flash memory recorder (originally) for $299?... (currently $250)? Yes, and it has no input side mixing, no EQ, it records only 2-tracks simultaneously, 5/6 & 7/8 are linked pairs, and the preamps are hissy! But hey,... it's 8-tracks for $250! Y'gotta give to get. Y'gotta give up some higher features and quality to get 8-tracks for $250.
I'm afraid that's how the game is played, or how the gear wars are fought.
There are numerous MR8 threads in the Fostex forum, which will provide good background study on the MR8. I won't go on any further, as I've already posted my opinions of the MR8, numerous times.
(I've read) a Behringer UB802 would be low cost a problem-solver for the MR8's limited input mixing capability and preamp hiss problem.
You may want to call on MR8 users named "cellardweller", JUnplugged, ch2so7, or Dave in Toledo for actual user's advice.
BEST OF LUCK!
PS: there is no defined "culture" on this board. Just be yourself, ask your questions, and be prepared for e'one to offer their own opinion as if it's the gospel truth! ... along with the usual cast of jokesters, ballbusters and trolls that you'd find on any board!!
