Yes it's not really a bias issue as such. High bias tapes tend to be high energy tapes but that's an indirect correlation.
Crosstalk is generally not a huge issue as with a normal multitrack, the crosstalk is occuring at exactly the same moment across all tracks. Since it's not heard as a separate sound it doesnt stand out much. Any crosstalk gets masked by "itself" on the originating track. Only if you were wanting to completely cut that instrument or voice from the mix might you have some audible crosstalk.
With high energy recordings, usually more of an issue than crosstalk is print through, the pre and post echo on the same track. In my experience, print through can be more of a problem, and the longer the tape is stored, and the higher the storage temperature, the worse it gets.
Again, print through is a problem due to the analog nature of the recording method, which requires capturing a very wide range of frequencies on the one tape track. While there's little or no print through with the high frequencies there is increasingly more print through, the lower the frequency.
Higher energy tapes only made the print through issue worse. In practice, using thicker base tapes, storing tapes "tail out" where possible, conservative recording levels and storage of tapes in a cool environment are good safeguards.
Tim
