W
wishtheend
I currently am playing in a band that is drop C, and of course taking a normal set of strings down a whole set from Drop D is going to cause some serious loosness. I've tried a set of GHS Boomers where the lowest string is .115 and It's doing much better, but I'm thinking it could stand to be a little tighter on the tension. You see, I play alot of fast metal things that need me to do alot of quick rhythm picking (lamb of god, dillinger escape plan). I'm playing an ESP Viper-254 bass (EMG pickups).
Would it just be best to get a 5-String and tune it like the guitar would be (C-G-C-F-A) or should I just slap a 5-string set on this four string (dropping that high string)? Another question would be, when I put that thicker set of GHS Boomers (the .115), the string is thicker than the slot it rests in on the bridge. Do any of you know if it's common to have those filed out so thick guages could rest? And would anything else needed to be done to my bass if I decided to just throw a 5-string set (dropping the highest string) ?
Thanks for any info you guys can give.
